Brass adjusters on top of later forks, how many clicks??
graham72
Bike owned: NC30,
Post by graham72 »
As title really, how many clicks should the brass rebound adjusters on the top of later forks have?
I'm just about to replace my damper rods with another pair that arent seized and one has 8 clicks and the other has nine.
can they be adjusted, if so how?
Graham
arsey30
Bike owned: ftr223 650 bros
Re: Brass adjusters on top of later forks, how many clicks??
Post by arsey30 »
Loosen the damper rod lock nut and turn the damper rod within the adjuster housing [up or down] to calibrate.
15 clicks max is correct.
Dave.
graham72
Bike owned: NC30,
Post by graham72 »
arsey30 wrote:Loosen the damper rod lock nut and turn the damper rod within the adjuster housing [up or down] to calibrate.
Dave.
Ok thats completely confused me, at the moment I have the damper rod in my hand, it doesnt have the fork top on it, is the locknut the nut right at the bottom? what bit is the adjuster housing????
sorry for being a dumbass!!
Graham
arsey30
Post by arsey30 »
The large [M37] fork top bolt screws onto the adjuster housing, it is the part with brass screw in the top of it.
The lock nut is at the top of the rod, beneath the adjuster housing to lock them together.
Dave.
graham72
Bike owned: NC30,
Post by graham72 »
Cheers dave, all sorted 15 clicks per side and completely seize free adjusters! yay!
Cheers for the help, have some karma!
Graham
