OIL PRESSURE SWITCH
GIXERMARK0
OIL PRESSURE SWITCH
Post by GIXERMARK0 »
HI
LOOKING TO CHANGE THE OIL PRESSURE SWITCH
unfortunatly i dont have a workshop book yet so could some one point me in the correct direction to where it is on the engine
i asked at my local Honda dealers and they could not find it on the micofish
cheers mark
hardnutdvd
Regular Member
Bike owned: RVF400 NC35
Re: OIL PRESSURE SWITCH
Post by hardnutdvd »
from the Haynes
"the oil pressure switch is screwed into the crankcase between the cylinders, and is accessed by removing the lower fairing.
Pull the rubber cover off the switch and remove the screw securing the wiring connector.
with the ignition switched ON, earth (ground) the wire on the crankcase and check that the warning light comes on. If the light comes on, the switch is defective and must be replaced."
GIXERMARK0
hi
thanks for the info
but it you ground the wire and the light comes on then the wireing and bulb is ok
my oil light comes on at tick over when warm so it could be the oil but wanted to change the switch just in case its faulty
