Thanks Sam
best bet is to take the hub out and use a telescopic magnet thingy, its hollow down the centre, other wise a homemade magnet on a something bendy one ideally, or one of the bendy grabber things,mintmansam wrote:hi, ok i have lost a 12mm socket in the swinging arm, i was tightening the rear manifold thing on the exhaust, i then removed the the ratchet but the socket was stuck to the nut, so i tapped with a hammer, it then fell into the suspension, then fell into the hole in swinging arm on the inside were the spring is, how can i get it out ,is the whole swinging arm hollow, can i take it off while leaving the hub intact or is there another access point![]()
Thanks Sam
The exact same thing happened to me! Couldn't believe it, had to pick the back of the bike up in the air and got my girlfriend to grab it with a magnet on a stick when we heard it roll to the front of the swing arm near the pivot.mintmansam wrote:done it lol. thanks for the idea , took some magnets ( ripped them out ) of an old calculator case, attached some stirng to it , then put it down the same hole but couldnt't get it so to push down as it is string lol so attached a tie wrap to the magnet pushed it down the swinging-arm it grabbed the socket, felt like it was 15cm down so somewhere in the middle , didnt need to take the hub off, must say thanks for the idea
Ha ha first thing i said that to myself when the socket dropped in the swing arm!porndoguk wrote:thats why you all need expanding foam :D
But what about your power to weight ratio?!porndoguk wrote:thats why you all need expanding foam :D
