nc24 top speed
- Bike owned: cub90x5 nc21 nc24
nc24 top speed
Hi had my nc24 for almost a year now and loving it but every were i read they say its suppose do at least 125mph with head down but mine has a mint engine an will only pull 102 mph sitting up and 112 with my head down this is in 4th gear if i then change up to 5th or 6th it starts slowing down im running a 14 t front and 45t rear any help would be appreciated
Re: nc24 top speed
is it restricted (33bhp)
- Hadies
Re: nc24 top speed
CMSMJ1 wrote:is it restricted (33bhp)
Does it 'bog' down at higher revs when you give it a handful?
Re: nc24 top speed
no not restricted full power had it put on a dyno when first got it and is putting out 57hp @ 13000 and 25 ft-lbs @ 10000 it is a naked bike tho so gooing to lose some top speed from that i now
Re: nc24 top speed
no bogging it runs sweet as will fly up to about 100mph
Re: nc24 top speed
Have you got the dyno graph?
Something is not right as they'll do 120 easy...
- Hadies
Re: nc24 top speed
Do 24s have the rubber flap that direct air like on the 30?
Re: nc24 top speed
yea iv got the graphs the guy how did the dyno run said it was a tiny bit lean so put the 115 main jets in the front and 118s in the back which made a nice improvment an run smooth thro the revs and the rubber flap um yea it did have one but think i left it off when put the bike back together will have a look
Re: nc24 top speed
If you have messed with the flaps and so on it can often make it run shit...
They don't have ram air, they don't need any air "forcing " down their throat. Leave them std..Honda have the skills.
Am sure you'll get it right
Re: nc24 top speed
just had a look at rubber flap an no it dose not have one it was a different bit i was thinking of it was the peace from under the bottom yoke
