Foiks oil leak after seals changing.
Hi guys,
I have changed forks dust and oil seals, but oil steel leak. Not too much, but when left bike on night at garage I get blot of oil on the floor. I think it due to oil overflow - maybe I put too much oil, but I measure and put about 450 millilitres to each fork.
Re: Foiks oil leak after seals changing.
did you use honda genuine seals ?, you can buy leakproof garunteed ones as well, you didnt mark the fork tube , was the tube in good condition ( ie no rust or damge which may have caused them to leak in the first place)
Eddie
Eddie
Unfortunately, I didn't use honda genuine seals. All fork tubes in good conditions - no marks, rust or damage.. I think there only two reason - bad seal or oil overflow. Bough this one from ebay http://cgi.ebay.com/ebaymotors/Honda-CB ... 0066083656
- leopard_pagan
leakproof guaranteed ones as well
>where? coz i know id get them replaced for free.. lol mine always leak once a year.
http://www.motohaus.com/html/seals/leak ... 0intro.htm" onclick="window.open(this.href);return false;
these are the kiddies
http://www.motohaus.com/acatalog/copy_o ... seals.html" onclick="window.open(this.href);return false;
Eddie
Eddie
- Sligeach
i did mine in the ZX6 in the past week, and i thought they were leaking but if you pop off the dust seal and dry around the fork seal. then push the dust seal back into position and go for a ride.
after the ride pop up the dust seal and see if there is oil around the fork oil seal.
worked for me, it was just oil i used to lube the tube as i slid on the fork seal
- leopard_pagan
they dont list the NC29/23 on the site, but they do list the NC30... arent their forks the same as ours?
For CBR 400 NC29 fit
Size - Fork Seal Dimension : 41mm x 54mm x 11mm (7247)
But only one questions, where is the guaranty it is really oil leakproof.
I had the same bother fitting pkn seals
All nc's are the same seals.
Buy honda ones from dave silver spares. i found them a lot cheaper than my local dealer .
good luck.
drew.
good luck.
drew.
