Coerce Rearsets Question
Cru Jones
Bike owned: NC35
Post by Cru Jones »
So, I got a set used and they're missing the spacers that go behind them. You know, the ones in the pic below. Can someone please measure their spacers, so I know what I need to buy from the industrial supply place? Yes, I know I can just buy a bunch of M8 washers, but I'd prefer just to have a properly sized spacer if possible. :geek: Thanks.
Re: Coerce Rearsets Question
Why not get yourself some washers, space them out as you like it - and the buy a spacer to match?
Cru Jones
Bike owned: NC35
Post by Cru Jones »
CMSMJ1 wrote:Why not get yourself some washers, space them out as you like it - and the buy a spacer to match?
Well, I could do that or I could just find out what size spacer it is from someone who already has the stock Coerce spacers. ;)
uber pikey
Bike owned: NC30, GS700e GSX750 katana pop
Post by uber pikey »
I think you should buy a lathe, turn some spacers out and then let everybody know that you have a certain size spacer, oh and stop being selfish lol :?
I saw it so I took it!
Cru Jones
Bike owned: NC35
Post by Cru Jones »
uber pikey wrote:I think you should buy a lathe, turn some spacers out and then let everybody know that you have a certain size spacer, oh and stop being selfish lol :?
Sadly, my access to such a lathe won't exist soon as I'm moving away from my good friend that does that sort of stuff. :(
Hadies
Post by Hadies »
They look like the same spacers you get with SES rearsets. If you can't get dimensions from here then I suppose you could try getting in touch with SES.
Cru Jones
Bike owned: NC35
Post by Cru Jones »
Hadies wrote:They look like the same spacers you get with SES rearsets. If you can't get dimensions from here then I suppose you could try getting in touch with SES.
I wouldn't worry about it. If nobody posts up in the next few days then I'll just figure it out via CMSMJ1's method.
Rearset spacers are usually 10mm thick
porndoguk
Post by porndoguk »
just buy some alloy rod, 20mm dia etc, drill and cut to required size :whistle:
Cru Jones
Bike owned: NC35
Post by Cru Jones »
porndoguk wrote:just buy some alloy rod, 20mm dia etc, drill and cut to required size :whistle:
Actually, I found a site that just makes al spacers, aptly named 'aluminum-spacers.com.' So, job done. :grin:
