Coerce Rearsets Question
- Cru Jones
- Bike owned: NC35
So, I got a set used and they're missing the spacers that go behind them. You know, the ones in the pic below. Can someone please measure their spacers, so I know what I need to buy from the industrial supply place? Yes, I know I can just buy a bunch of M8 washers, but I'd prefer just to have a properly sized spacer if possible.
Thanks.
Re: Coerce Rearsets Question
Why not get yourself some washers, space them out as you like it - and the buy a spacer to match?
- Cru Jones
- Bike owned: NC35
Well, I could do that or I could just find out what size spacer it is from someone who already has the stock Coerce spacers.CMSMJ1 wrote:Why not get yourself some washers, space them out as you like it - and the buy a spacer to match?
- uber pikey
- Bike owned: NC30, GS700e GSX750 katana pop
I think you should buy a lathe, turn some spacers out and then let everybody know that you have a certain size spacer, oh and stop being selfish lol
I saw it so I took it!
- Cru Jones
- Bike owned: NC35
Sadly, my access to such a lathe won't exist soon as I'm moving away from my good friend that does that sort of stuff.uber pikey wrote:I think you should buy a lathe, turn some spacers out and then let everybody know that you have a certain size spacer, oh and stop being selfish lol
- Hadies
They look like the same spacers you get with SES rearsets. If you can't get dimensions from here then I suppose you could try getting in touch with SES.
- Cru Jones
- Bike owned: NC35
I wouldn't worry about it. If nobody posts up in the next few days then I'll just figure it out via CMSMJ1's method.Hadies wrote:They look like the same spacers you get with SES rearsets. If you can't get dimensions from here then I suppose you could try getting in touch with SES.
Rearset spacers are usually 10mm thick
just buy some alloy rod, 20mm dia etc, drill and cut to required size
- Cru Jones
- Bike owned: NC35
Actually, I found a site that just makes al spacers, aptly named 'aluminum-spacers.com.' So, job done.porndoguk wrote:just buy some alloy rod, 20mm dia etc, drill and cut to required size
