Bike only starts from Neutral (Safety cut out?)
vr46
- Bike owned: All sorts
Hi,
My NC29 will only start when in neutral, this is a problem because I want to be able to bump start the bike.
How can I bypass this cut out?
The bike is going on a trackday so I shall remove the side stand and cable.
Thanks,
Thanks,
- hallsie
- Bike owned: NC29
Re: Bike only starts from Neutral (Safety cut out?)
I cant remember if it'll start with the clutch in or not whilst in gear but disconnecting the switch alltogether will probably not do any good at all
kate beckinsale....... mmmmmmm
vr46
It will start with the clutch in or out as long as it is in neutral.
I want the option of starting it with rollers (as a backup)
I'll take another look.
Thanks.
Thanks.
amorti
- Bike owned: CB-1, MSX125
Do you have a wiring diagram? Trace the line the electricity can take with each safety switch in whatever position.vr46 wrote:It will start with the clutch in or out as long as it is in neutral.
Thanks.
It sounds to me like you bike has the clutch switch faulty. Will it continue to run in gear with the kickstand down? Could also be the kickstand switch, but my money is on the clutch switch. Just bridge the two wires with a paperclip and report back.
- hallsie
- Bike owned: NC29
As above I reckon it's the clutch switch , put mine in gear tonight held in the clutch and started first turn no problem
vr46
Hi all, sorted it.
Some wiring was needed to make the bike think the stand was up all the time. Thx.
amorti
http://www.cambridge-news.co.uk/Home/Si ... -death.htmvr46 wrote:Hi all, sorted it.
Easy now...
Wozza
Just remember it's there, like all us tri-arm owners do.
