Gear indicator
The Dark Prince
Gear indicator
Hi
Anyone fitted a gear indicator to an NC30, any recomendations
ludacris
- Bike owned: NC35
Re: Gear indicator
haven't fitted one but...i think the GPT is a top choice, has an OEM look about it...
- mattUKNC
The Dark Prince
Re: Gear indicator
how does it connect/ sense - looking at the wiring diagram I only have wires to neutral switch that goes into the gearbox or does it somehow pick up from the ignition control.
- mattUKNC
Re: Gear indicator
The SP1 has a pulse from the CDI for the Rev counter, this is used on the one I fitted. You still had to then go through the gears for the unit to 'learn' the gears.
Pretty straight forward fitting on that bike, as it came with an SP1 specific loom!
cragionvfr
- Bike owned: NC30, ZX7R
Re: Gear indicator
http://www.mandp.co.uk/productInfo.aspx?catRef=560571
had one on my fzr250 and had to use this kit, it was pretty straight forward to do so im sure it would be fine on the NC. i reckon it would be very visible on the front wheel as there is no speedo cable to run the wire down. wouldn't mind one on my 7R
veefer400
Re: Gear indicator
They connect into the loom on bikes with an electronic speedo/revcounter and work by comparing revs/mph etc... was looking to fit one to my VFR VTEC - would be handy on my '23 tho, always going for 7th...The Dark Prince wrote:how does it connect/ sense - looking at the wiring diagram I only have wires to neutral switch that goes into the gearbox or does it somehow pick up from the ignition control.
