(Lack of) rev limiter - NC23-J Gold ECU
Townsend87
Post by Townsend87 »
Hello,
My NC23 has a gold stickerd' ECU fitted, which i thought was standard. However i have discovered it has no rev limiter (hit false neatral between 5th & 6th at about 100!). Has anybody had the same problem? and do they know if this is standard for a J model NC23?
C
Yakama
Re: (Lack of) rev limiter - NC23-J Gold ECU
Post by Yakama »
The J model NC23 Triarm should have a gold cdi yes, should be marked KY2 on the gold sticker.
w00dzy
Bike owned: Aprilia RSVR Mille
Post by w00dzy »
Be careful with no limiter matey...
Townsend87
Thats my main concern although i have only been caught out once, but its really annoying on tracks still.
has anybody had the same problem tho? it cant be a standard CDI right?
C
jac_is_smiling
Bike owned: Cagiva Planet, NC23 x2, FZ 600
Post by jac_is_smiling »
It may be because the redline is at 14k5 and the limiter cuts in at about 15k5. That extra 1000rpm obviously isnt meant to be used (too often) but can be somewhat usefull on ocasion. Little bit worrying seeing the needle woosh past the redline and go +15k
Failing that your ignition may be (slightly) broke, gold sticker sounds like a standard RRJ one.
if you have not blown it up, how do you know there is no limiter? Just by the tacho reading? Sure that is accurate?
Townsend87
thanks for the comments,
when i bought the bike the guy said it was a de restricted CDI unit, but with the gold sticker it looks like a standard unit to me. Its only gone to 17k once, and this was ages ago now and not blown up! lol.
i can only assume now that the ignition is slightly broke! seems to run awesome tho still tho! :D
C
blueflag
Post by blueflag »
I once spent a whole season racing an R6 where the tacho (previously accurate) started reading about 20% high, I thought the limiter was faulty too. It was only highlighted when I put it on a dyno............. :?
tanuki
Post by tanuki »
Townsend87 wrote: it looks like a standard unit to me.
It is...
The earlier 23s had an unrestricted gold label CDI, the later models came with a restricted to 112mph blue label CDI.
It's nothing special.
Townsend87
Thanks again guys,
i think it may be a 'slightly' broken ignition as it seems to top out just fine at 125-30ish.. i dont think nc23s go any faster? Or do they??
maybe once i get £££'s il fix it! :/
C
