1WG Fork Oil
fzrbob
- Bike owned: Yamaha FZR 400 1WG
1WG Fork Oil
Hi Guys,
finally got the 1wg run up the road but the front forks are real soft. I guess a change of oil and maybe some spacers on the springs will do the trick, but i can't find which oil to put in or what air gap there should be?
anyone any idea or can point me to some good resources for this??
cheers
cheers
oollit
- Bike owned: FZR400RR 3TJ, RF900R
Re: 1WG Fork Oil
Depends on what model you have, here are some of the front suspension specs from a previous post.
I used 15w oil instead of 10w, made a big differance on my 3TJ.
The FZR400A and FZR400SCA were what the yank model were called but I can't remember which Jap models they were.
FZR400RR 3TJ
43mm Fork Tubes
Fork Spring Free Length - 346mm
Minimum - 341mm
Spring Rate - 6.5N/mm (0.65Kg/mm)
Fork Travel - 120mm
Oil Capacity - 509cm3 (17.9Imp Oz)
80mm From the top of inner tube, fully compressed without spring.
10w Oil
FZR400SP 3TJ
43mm Fork Tubes
Fork Spring Free Length - 359mm
Minimum - 354mm
Fork Travel - 120mm
Oil Capacity - 433cm3 (15.2Imp Oz)
106mm From the top of inner tube, fully compressed without spring.
10w Oil
FZR400A
Fork Spring Free Length - 412mm
Minimum - 408mm
Spring Rate - 4.4N/mm (0.5Kg/mm)
Fork Travel - 130mm
Oil Capacity - 440cm3 (15.5Imp Oz)
92mm From the top of inner tube, fully compressed without spring.
10w Oil
FZR400SAC
Minimum - 408mm
Spring Rate - 6.6N/mm (0.7Kg/mm)
Fork Travel - 130mm
10w Oil
FZR400RR 3TJ
43mm Fork Tubes
Minimum - 341mm
Fork Travel - 120mm
10w Oil
FZR400SP 3TJ
43mm Fork Tubes
Minimum - 354mm
Fork Travel - 120mm
10w Oil
FZR400A
Minimum - 408mm
Fork Travel - 130mm
10w Oil
FZR400SAC
Minimum - 408mm
Fork Travel - 130mm
10w Oil
oollit
Re: 1WG Fork Oil
It just dawned on me that you probably have a Genesis, which I think was the FZR400RU.
Did a quick search and came up with this...
http://www.fzrarchives.com/ipb/index.ph ... opic=48830
You will need to register to view the manual. I have forgotten my login details as I haven't used this site in ages so I couldn't access it.
dancon3105
- Bike owned: FZR400 1WG
Re: 1WG Fork Oil
Genesis /FZR400U/FZR400W (the non-EXUP bikes) 444ml /92mm Gap.
There are downloadable manuals (& parts lists) around for this to confirm.
Think the 'U' is Japanese & 'W' is US
