Headlight Help
spooner
Headlight Help
One of my headlight bulbs went the other day when i was out for a ride, so after finding a supplier of bulbs (12v 60/35w at £20 each
) i fitted it and it still didnt work, now the other bulb has gone too so i am left with no dipped beam
, i have checked the fuse under the pillion seat and its ok. has anyone else had this problem and if so how did u fix it. I have now found the bulbs online for £8.45
so willorder a couple up but i dont want to fit them until the prob is sorted. any help would be welcome
Re: Headlight Help
knackered left hand switchgear.... open it uip, it imght be salvagable. clean all the burnt/melted stuff out of it and see how you go..
- ibby4585
- Bike owned: SP's
Re: Headlight Help
Alan, Isnt your NC UK spec?
Kris
Kris
spooner
Re: Headlight Help
would that cause the bulbs too blow having dodgy switch gearCMSMJ1 wrote:knackered left hand switchgear.... open it uip, it imght be salvagable. clean all the burnt/melted stuff out of it and see how you go..
spooner
Re: Headlight Help
well the more i look at the the frame and fairing is but the electrical side of things look to be japibby4585 wrote:Alan, Isnt your NC UK spec?
Kris
- ibby4585
- Bike owned: SP's
Re: Headlight Help
spooner wrote:well the more i look at the the frame and fairing is but the electrical side of things look to be japibby4585 wrote:Alan, Isnt your NC UK spec?
Kris
What were the bulbs you took out? Matbe somebody has put H4 bulbs in thinking it was a UK spec then and frazzled the switchgear!
Re: Headlight Help
That is what I was thinking...
spooner
Re: Headlight Help
they were the 12v 60/35w bulbs, I took one out to go and find the new ones
graham72
- Bike owned: NC30,
Re: Headlight Help
Surely he'd be able to tell if the bulbs were uk ones apart from the wattage the headlight would of had to be modded for the H4 tabs?ibby4585 wrote:spooner wrote:well the more i look at the the frame and fairing is but the electrical side of things look to be japibby4585 wrote:Alan, Isnt your NC UK spec?
Kris
- ibby4585
- Bike owned: SP's
Re: Headlight Help
Spooner has got a bit of a bitsa, half UK half Jap! The frame is UK as is log book but engine and other bits appear to be Jap, i just wondered if they had changed the Uk Headlights too!
