Headlight Help
spooner
Headlight Help
Post by spooner »
One of my headlight bulbs went the other day when i was out for a ride, so after finding a supplier of bulbs (12v 60/35w at £20 each :cry: ) i fitted it and it still didnt work, now the other bulb has gone too so i am left with no dipped beam :down: , i have checked the fuse under the pillion seat and its ok. has anyone else had this problem and if so how did u fix it. I have now found the bulbs online for £8.45 :x so willorder a couple up but i dont want to fit them until the prob is sorted. any help would be welcome
Re: Headlight Help
knackered left hand switchgear.... open it uip, it imght be salvagable. clean all the burnt/melted stuff out of it and see how you go..
ibby4585
Bike owned: SP's
Re: Headlight Help
Post by ibby4585 »
Alan, Isnt your NC UK spec?
Kris
spooner
Re: Headlight Help
Post by spooner »
CMSMJ1 wrote:knackered left hand switchgear.... open it uip, it imght be salvagable. clean all the burnt/melted stuff out of it and see how you go..
would that cause the bulbs too blow having dodgy switch gear
spooner
Re: Headlight Help
Post by spooner »
ibby4585 wrote:Alan, Isnt your NC UK spec?
Kris
well the more i look at the the frame and fairing is but the electrical side of things look to be jap
ibby4585
Bike owned: SP's
Re: Headlight Help
Post by ibby4585 »
Kris
What were the bulbs you took out? Matbe somebody has put H4 bulbs in thinking it was a UK spec then and frazzled the switchgear!
Re: Headlight Help
That is what I was thinking... :ugeek:
spooner
Re: Headlight Help
Post by spooner »
they were the 12v 60/35w bulbs, I took one out to go and find the new ones
graham72
Bike owned: NC30,
Re: Headlight Help
Post by graham72 »
ibby4585 wrote:
Kris
Surely he'd be able to tell if the bulbs were uk ones apart from the wattage the headlight would of had to be modded for the H4 tabs?
ibby4585
Bike owned: SP's
Re: Headlight Help
Post by ibby4585 »
Spooner has got a bit of a bitsa, half UK half Jap! The frame is UK as is log book but engine and other bits appear to be Jap, i just wondered if they had changed the Uk Headlights too!
