FZR 400 3tj Info please.
Tomahawk
Hi im looking to purchase a fzr 400. would anyone be able to tell me the problem you could get with the bike and if they are easily fixable.
cheers
cheers
nick
Re: FZR 400 3tj Info please.
The 400 is generally a reliable bike, all of the 3TJ's i've owned (i'm on number 3) have been fine with no problems to talk about.
As long as the bike is well maintained and serviced regularly then you will get many miles of enjoyable riding (but that goes for any bike)
I have heard of people having a few problems with the EXUP system if its not adjusted properly and at higher mileages the top end is prone to a few rattles if the valves are not checked
No doubt the rest of the gang will add anything else worth mentioning
Nick.
Nick.
Tomahawk
The bike i may be getting has been off the road for 2 years it says it will need servicing hoping everythings ok with it if i get it.
do you get much problems with the cams? or as you said if its serviced regularly they will be fine?
Tom
Tom
The cams themselves are going to be fine - you'll need to service it and spray a little 3in1 oil down the spark plug holes before you turn it over.
Check the exhaust downpipes carefully for rust - the pipes are a Yam only part.
Ask if the valve clearances have been done - it maybe that's what the owner is talking about when they say about the cams
Tomahawk
the owner hasnt said anything about the cams. its been off the road for just under 2 years but has been started nearly every day they said. so if thats true the bike should be ok.
tom
tom
If what they say is ture ... I'd have thought every week would be more probable though.
I'd still service it - all the filters and fluids, then it will need a decent ride
Tomahawk
Yeh i wont be doing my test for about another month so my dad is going to service it and ride it to make sure it runs ok. its the 1994 uk model so if it runs fine will be a really good bike.
tom
tom
Sounds nice .... but we need pictures
Tomahawk
will try to put pictures up if i get it. as im new to this forum havent a clue on how to put the pictures on haha
Taggyd
read the sticky post on how to put up pictures! check the fork seals as well if it's been stood for a while! check the tyres are ok before riding as well.
