rear set jack up plates
spongy.bob
Post by spongy.bob »
Hi all,
I'm having trouble fitting some rear set jackup plates to my nc30. I can fit the plates themselves but when I try and fit the original rear sets using the original bolts, the bolts are stopped by the frame on the other side. Will I have to cut the bolts?
royster81
Re: rear set jack up plates
Post by royster81 »
cut them or get shorter one's ,simple'
superlite
Bike owned: TLS, LB80 x 2
Post by superlite »
steady.bob wrote:Hi all,
Have you fitted the spacers behind the jack-up plates? They shouldn't hit the frame.
'Take it to the Back'
spongy.bob
Spacers?
I didn't get any spacers!
I plates I have look identical to the Race Dirrect ones on Ebay. All I've got are the plates and four countersunk bolts. Maybe I've been done!? :twisted:
spongy.bob
Do you think you could pop a picture of the spacers/ give a linkto them, so I know what I'm loooking for?
superlite
Post by superlite »
steady.bob wrote:Do you think you could pop a picture of the spacers/ give a linkto them, so I know what I'm loooking for?
I don't have jack-up plates, but I have in the past. Post a pic up of what you've got (mock fitted if you can) and we can diagnose it.
spongy.bob
Cool! 8-)
Ill put them up tomorrow (or today if your in Australia) :geek:
spongy.bob
Hi all,
sorry for the extended break on this thread. turns out superlite was right, I do need the spacers for the plates. Could someone tell me how long the spacers are and I can get some made up?
Rob.
superlite
Post by superlite »
Wow, forgot about this!
They'll be different sized spacers to a regular aftermarket rearset because the plates act as a spacer too. Best option would be to grab a heap of washers, pack it out and fit it until the rearset clears the swingarm, then measure the washer stack and make spacer to the correct dimensions :peace:
spongy.bob
Easy as that :oops:
Karma 4 u! :ugeek:
