rear set jack up plates
spongy.bob
Hi all,
I'm having trouble fitting some rear set jackup plates to my nc30. I can fit the plates themselves but when I try and fit the original rear sets using the original bolts, the bolts are stopped by the frame on the other side. Will I have to cut the bolts?
- royster81
Re: rear set jack up plates
cut them or get shorter one's ,simple'
- superlite
- Bike owned: TLS, LB80 x 2
Have you fitted the spacers behind the jack-up plates? They shouldn't hit the frame.steady.bob wrote:Hi all,
'Take it to the Back'
spongy.bob
Spacers?
I didn't get any spacers!
I plates I have look identical to the Race Dirrect ones on Ebay. All I've got are the plates and four countersunk bolts. Maybe I've been done!?
spongy.bob
Do you think you could pop a picture of the spacers/ give a linkto them, so I know what I'm loooking for?
- superlite
I don't have jack-up plates, but I have in the past. Post a pic up of what you've got (mock fitted if you can) and we can diagnose it.steady.bob wrote:Do you think you could pop a picture of the spacers/ give a linkto them, so I know what I'm loooking for?
spongy.bob
Cool!
Ill put them up tomorrow (or today if your in Australia)
spongy.bob
Hi all,
sorry for the extended break on this thread. turns out superlite was right, I do need the spacers for the plates. Could someone tell me how long the spacers are and I can get some made up?
Rob.
Rob.
- superlite
Wow, forgot about this!
They'll be different sized spacers to a regular aftermarket rearset because the plates act as a spacer too. Best option would be to grab a heap of washers, pack it out and fit it until the rearset clears the swingarm, then measure the washer stack and make spacer to the correct dimensions
spongy.bob
Easy as that
Karma 4 u!
Karma 4 u!
