nc35 air problems
nc35 air problems
hii all
i was told half system airboxes were good...i took my box lid off so its just filter but when i get to 9500 rpm its hardly excelerates through feels like it is miss firing is it because it has to be tuned or anything...please let me know what u think i am new to this so no insults as i am learning thanks
- skinnydog0_0
- Bike owned: Penny Farthing
Re: nc35 air problems
Hi is the bike standard? or do you have a different exhaust, different jets?
i have race pipes and a tyga maggot can
- skinnydog0_0
I am no expert on carb set up, but if you adjust the amount of air then you will have to adjust the amount of fuel. more air = more fuel in general terms. Getting the balance right is not always easy. Do you run standard jets?
Put it back to standard... simple!
You will be running dangerously lean as it stands now..big time lean.
ALso - use the search..If I could be arsed I would bore you with the settings I use...but I have work to do..lol
Thye are on here though!
i am using standard jets
and could you please post a link to the thread with the settings and are the settings for a rvf400
put the airbox lid back on then! Simple.
I have personally posted in over 20 thread with the settings I have used and do use for my bikes.
I have an NC30 with RVF carbs..no airbox lid, half system etc etc..
I dont wish to sound rude CMSMJ1 as i do understand that you have probably told people info over and over and over again, but i have tried using the search and each time i use it it tells me that my search is to broad. It does not like using NC35 or Carbs or RVF or Settings and if it does return a search it hasnt used all of my search terms. When i searched for the misfire problem i was having the other day i ended up with FZR threads CBR threads and hardly anything the was relevant to the NC35!
yeah thats what i keep getting sorry if it takes time away from your work but when you can could u please post a link it would be much appreciated
Hi there dr_46 try the advanced search its a bit hit and miss but i managed to get to pg 5 out of 45 on carb setting withing the V4 workshop section of there forum before it booted me out you never know you may have a bit more luck
Regards
Regards
