nc30 struggles taken off/lost power
vfr-nc30-2010
- Bike owned: vfr nc30
hey all
having lil problem with my nc30!
when trying to pull away i have to keep dippin the clutch to actually get sum speed up to drive
also it dont feel very powerful when driving?
my m8 has a nc30 and his bike is like a TROUSER FIREWORK....... any 1 have any ideas what it may be
got brand new air filter
plugs got from m8 said the were new and did look it but cant be sure
carbs i cleaned but not sure if the need balancing , as it idles fine sum times it sounds like its missing when idle
please help me
please help me
Re: nc30 struggles taken off/lost power
What else have you done to it?
What filter? Have you messed with the airbox? Is this lack of go at 5-6k rpm?
vfr-nc30-2010
hi yeah the air filter looks like there is a slight lil gap , air filter is standard black casing with red in middle hrc i think
also sum times i can hear poppin sounds from under the tank??????
and yes when it revs to about 3 to 4 rpm it struggles then bout 5 to 6 its ok?
also had front head changed n shims and valves done new gaskets 2!
So , What jets were in it? Is the airbox all there, including snorkel and the rubber flap above the top rad?
The std filter is a folded paper jobbie. HRC foam is see thorugh..so you don't have one of them :-)
vfr-nc30-2010
ok lol this what i have
Have you got the snorkel in the front of that airbox? Or is it a large hole?
nice and clean though..love it!
vfr-nc30-2010
thanks the rubber scoop aint on the bike (scoop that cools carbs down)
and on front of the air filter theres a bendy rubber slot facing down towards front plugs if u under stand that lol
- superlite
- Bike owned: TLS, LB80 x 2
Here's a flap:
Here's a snorkel:
Is that what you've got?
Here's a snorkel:
ChowderV4
Ooo my airbox doesn't have that snorkle , will that make a big difference
vfr-nc30-2010
hi have the snorkle but no flap!
