RVF NC35 Front end on CBR NC29 - Big job?
- Bike owned: All sorts
Hi All,
I have seen a few threads about this topic already, however the linked information has expired from the forum.
I have seen a few NC29's with NC35 forks and it has sparked my interest
Please can someone share what work is involved, is it a big job?
Skint Novice F400
Re: RVF NC35 Front end on CBR NC29 - Big job?
It's bolt on... just remove NC29 front end and fit NC35. I did almost same with cbr6000rr07 front end
- Bike owned: 1990 CBR400RR-L NC29
is it include the triple clamp etc ? or can we use NC29 clamp ? how about the rim ?PARUS wrote:It's bolt on... just remove NC29 front end and fit NC35. I did almost same with cbr6000rr07 front end
You have to use the NC35 clamps - they are bigger due to USD...
So, good luck finding the clamps!
OK, if I had a FULL RVF front end (everything) then is it a direct fit?
Is it a simple direct replacement with no mods at all
I assume the forks will accept an NC23,29,30 wheel as this is shared across the model range?
Thanks,
Thanks,
Skint Novice F400
I'm not sure about NC23 wheel, because it different than NC29/NC30/NC35
I run an NC23 wheel in my NC30, so they fit no worriesPARUS wrote:I'm not sure about NC23 wheel, because it different than NC29/NC30/NC35
I run the NC23 - 3 spoke wheel in my NC29 as it is ligter.
Does anyone have any details on the RVF front end fitting? Thanks
Skint Novice F400
- Bike owned: RVF400 NC23 x 2 NC29 CBR4/600
You cant get the NC35 forks on an NC23 as they are too short and when you brake, the forks bottom out on the mudguard and fairing. Tried it myself
However as the OPs question was for the NC29 the fact that they dont fit the 23 is kind of irrelevent...
