RVF NC35 Front end on CBR NC29 - Big job?
vr46
Bike owned: All sorts
Post by vr46 »
Hi All,
I have seen a few threads about this topic already, however the linked information has expired from the forum.
I have seen a few NC29's with NC35 forks and it has sparked my interest ;) Please can someone share what work is involved, is it a big job?
Thanks :!:
Skint Novice F400
PARUS
Re: RVF NC35 Front end on CBR NC29 - Big job?
Post by PARUS »
It's bolt on... just remove NC29 front end and fit NC35. I did almost same with cbr6000rr07 front end
zul_cbr
Bike owned: 1990 CBR400RR-L NC29
Post by zul_cbr »
PARUS wrote:It's bolt on... just remove NC29 front end and fit NC35. I did almost same with cbr6000rr07 front end
is it include the triple clamp etc ? or can we use NC29 clamp ? how about the rim ?
You have to use the NC35 clamps - they are bigger due to USD...
So, good luck finding the clamps!
vr46
Post by vr46 »
OK, if I had a FULL RVF front end (everything) then is it a direct fit?
Is it a simple direct replacement with no mods at all :?:
I assume the forks will accept an NC23,29,30 wheel as this is shared across the model range?
Thanks,
Skint Novice F400
PARUS
Post by PARUS »
I'm not sure about NC23 wheel, because it different than NC29/NC30/NC35
PARUS wrote:I'm not sure about NC23 wheel, because it different than NC29/NC30/NC35
I run an NC23 wheel in my NC30, so they fit no worries
vr46
Post by vr46 »
I run the NC23 - 3 spoke wheel in my NC29 as it is ligter.
Does anyone have any details on the RVF front end fitting? Thanks :grin:
Skint Novice F400
Mikiboy
Bike owned: RVF400 NC23 x 2 NC29 CBR4/600
Post by Mikiboy »
You cant get the NC35 forks on an NC23 as they are too short and when you brake, the forks bottom out on the mudguard and fairing. Tried it myself
tanuki
Post by tanuki »
However as the OPs question was for the NC29 the fact that they dont fit the 23 is kind of irrelevent...
