RVF - NC35 Squidgy front brakes
racytracy
Bike owned: RVF400RT & GSXR600K4
Post by racytracy »
Put new HEL brake lines on & new oil & front brakes still 'feel' a bit squidgy (compared to my GSXR600K4), any ideas please?
jimirobinson0
Bike owned: RVF400
Re: RVF - NC35 Squidgy front brakes
Post by jimirobinson0 »
Sounds like air is present. Try bleeding from the master cylinder end also.
If you ziptie the lever to the bars overnight that should encourage any bubbles in it to rise to the top - and make the lever much firmer than before..
ibby4585
Bike owned: SP's
Post by ibby4585 »
Ooh Good tip!! Will remember that!!
CMSMJ1 wrote:If you ziptie the lever to the bars overnight that should encourage any bubbles in it to rise to the top - and make the lever much firmer than before..
monkeywithaplan
Bike owned: NC35 and NC30
Post by monkeywithaplan »
i also found on the old RVF calipers when i had them if you have the pistons clamped right into the caliper, it makes it easier to expell and bleed through any air in the brake fluid.
