RVF - NC35 Squidgy front brakes
racytracy
- Bike owned: RVF400RT & GSXR600K4
Put new HEL brake lines on & new oil & front brakes still 'feel' a bit squidgy (compared to my GSXR600K4), any ideas please?
jimirobinson0
Re: RVF - NC35 Squidgy front brakes
Sounds like air is present. Try bleeding from the master cylinder end also.
If you ziptie the lever to the bars overnight that should encourage any bubbles in it to rise to the top - and make the lever much firmer than before..
- ibby4585
- Bike owned: SP's
Ooh Good tip!! Will remember that!!
CMSMJ1 wrote:If you ziptie the lever to the bars overnight that should encourage any bubbles in it to rise to the top - and make the lever much firmer than before..
- monkeywithaplan
- Bike owned: NC35 and NC30
i also found on the old RVF calipers when i had them if you have the pistons clamped right into the caliper, it makes it easier to expell and bleed through any air in the brake fluid.
