Black box under seat cowling???
graham72
- Bike owned: NC30,
Bored at work, so thought I'd take the seat cowling off and have a looksee!
There's a black box cable tied just above the rear lights with wires going in and coming out, says HRC not for highway use.
Anyone got any idea what it is??
- alexwitham
Re: Black box under seat cowling???
Genuine HRC CDI?
No - it reckon will be an SP box - it derestricts the Speedo.
Is there a CDI there too? WHich has only got wires going in... rather than in one end and out the other like the SP box..
Geek alert
Geek alert
graham72
- Bike owned: NC30,
Yep there's one other box underneath with one set of wires going in held down by two metal prongs!
graham72
- Bike owned: NC30,
While I've got the cowling off, what needs to be undone to move the undertray enough so I can get a pole on the end of the subframe to bring one side up? Have undone the two bolts at the end of the subframe.
fastdruid
Bolt for the header bottle and one hidden around the rear coils.
Best to remove the battery too.
Druid
Druid
graham72
- Bike owned: NC30,
Ok so just took air filter apart and should it have a paper element in it? Looks like the paper has been cut out and a piece of lightly oiled black foam about 3/4 inch thick has been put in it's place. Is this ok or should I get a new paper one??
fastdruid
Well it's OK, as to if you want to swap back to standard that's your call.
I think the consensus is that the standard filter flows pretty well.
Druid
Druid
- banoffee
check the jetting if you go back to a stock filter, mine have been jetted to suit...
i'm with mark, deffo a Desrestriction unit (providing its a jap bike
And as already been said.. check your jetting if you want to replace the foam with a std air filter as if it's been jetted to suit it'll run far too rich with a stock filter
