seat units
pgm
seat units
hi, can anybody tell me if an nc30 seat unit will fit a 35? its only for a race bike so if a little bit of trimming is required not a problem.
thanks. paul.
thanks. paul.
- Smev
- Bike owned: NC30 of course
Re: seat units
I have an NC35 seat unit for sale if you are interested - £20 - little scuff on one side but ideal for the track.
I'm in hampshire if you want to collect.
Smev
Smev
Mister Donut Rep NC30
pgm
Re: seat units
hi smev,Smev wrote:I have an NC35 seat unit for sale if you are interested - £20 - little scuff on one side but ideal for the track.
Smev
thanks for that but i'm ordering a seat from chris at infinity carbon and wondered as he used an nc30 to make it if it would fit a 35.
sorry should have made my post clearer.
Re: seat units
Mounting points are different on 30 and 35 units although im sure its possible with a little tweeking, i have 30 subframe on a 35 frame with a 35 seat unit so........
pgm
Re: seat units
we're going to have to alter the subframe a bit for the seat unit but hopefully all will work out ok.Drunkn Munky wrote:Mounting points are different on 30 and 35 units although im sure its possible with a little tweeking, i have 30 subframe on a 35 frame with a 35 seat unit so........
- Gavin jap4
Re: seat units
I think I have a NC30 subframe lying around if you want one £20 plus £8.50 P&P
fastdruid
Re: seat units
Easiest to fit the 30 subframe, main reason is that the 30 mounts to the subframe and to the frame the 35 mounts to the special subframe mounting bolts and plugs into the tank.
You *can* drill the 30 bodywork to fit but its so close to the existing mounts it gets a bit messy, the 30 subframe fits a treat.
Oooh, seems I did this once before
Druid
Druid
- superlite
- Bike owned: TLS, LB80 x 2
Re: seat units
A '35 seat unit fits a 30' subframe no worries (just different mounts - two are defunct), so I don't see why it wouldn't work the other way 'round? For racing: no probs.
'Take it to the Back'
