chain adjustment
				scratchin
chain adjustment
ok so its not a 400 but its got the vfr 800 rear swinger and wheel and i ain't got a clue how to adjust the chain any help appreciated
				Freekazoid
 - Bike owned: 91 NC30
Re: chain adjustment
if it is the same as the 400 then you loosedn the pich bolt which is about a 17 size bolt at the back end of the swing arm. then the tool which comes with the toolkit, looks like a C shaped spanner. connects in behind the chain turning clockwise to tighten chain & anti clockwise to loosen. if i remember right. tighten the pinch bolt when done & bob is your aunty??
It is, Even the double bearing is the same part#, which is taken from the NC24's swingarm
				venom51
Do your clocks run in reverse?Freekazoid wrote:if it is the same as the 400 then you loosedn the pich bolt which is about a 17 size bolt at the back end of the swing arm. then the tool which comes with the toolkit, looks like a C shaped spanner. connects in behind the chain turning clockwise to tighten chain & anti clockwise to loosen. if i remember right. tighten the pinch bolt when done & bob is your aunty??
- Deviant400
i was gunna say that, i did my chain bout a week ago but used a drive not a spanner as i aint got oneDo your clocks run in reverse?
viewtopic.php?f=62&t=27307
				Freekazoid
no i run off digital so don't know which way is right, ha ha. sorry my bad. small error.
