bit of a stupid question.. Rear brake
rich1988
Post by rich1988 »
Hiya, my rear caliper is off at the moment so I have no rear brakes, I got a new exhaust and I desperatley want to go for a ride to test it out, apart from the obviosus not having a rear brake is there any reason I shouldnt ride it? (the rear brake never really gets much use anyway)
Martin
Re: bit of a stupid question.. Rear brake
Post by Martin »
It's illegal, you might need to do a hill start, you might need to do an emergency stop.....please don't ride without a back brake as much for everyone elses safety as much as your own.
Too spensiff!!!
rich1988
Post by rich1988 »
Thought as much :), it will be staying on the track then, behind my house runs what was the old railway which genuinely is a private road/track i have ridden it up and down there a couple of times (its only about 100 meteres long) my second question is there any reason why I shouldnt move the bike around run it/ ride it up and down this piece of track with the rear caliper off and the brake fluid out (just from the rear brake) yes I am a noob I know I just want to make sure it wont be damaging anything by doing it :)
Spike16
Post by Spike16 »
I havent used my rear brake for 4 months.... I no this cos iv adjusted it so its well up and actually have to take my foot off the lever to press it.
you can easily do hill starts with the front brake and the rear brakes not gona help you much in an emergency stop (got cbr600 front brakes braided lines and m/s) so dont ever need to stop quicker.
Id say go for it but it is kindof illegal but I was thinking about it as a way of junking a fair bit of weight
rich1988
Post by rich1988 »
I'll play it safe and not bother but honestly I dont use the back brake at all, the only reason i wanted to sort it is because it was sticking on, is the rear brake on a seperate system to the front? cos i have ridden it up and down a bit and just wanna make sure im not risking breaking stuff :P
wullvfr
Bike owned: zx9r c1
Post by wullvfr »
rich1988 wrote:I'll play it safe and not bother but honestly I dont use the back brake at all, the only reason i wanted to sort it is because it was sticking on, is the rear brake on a seperate system to the front? cos i have ridden it up and down a bit and just wanna make sure im not risking breaking stuff :P
the rear brake is on a seperate system to the front.it has its own master cylinder and fluid reservoir.keep it fitted just in case you ever need it.you will save money on pads if you dont use it very often or at all.
a little pointer though,using your rear brake in and around villages and the city is much better than the front,its easier for tight maneovers.also if your into fast road riding trail braking can be a benefit and can help you turn the bike faster depending on what roads you are on.
wull
plus when y
wull
Agreed.
It's good for standing on hills / at lights, steadying the bike during slow speed manouvers, and invaluable for slowing the bike down mid corner when your a bit too hot... if you pulled the front brake you'd be off.
I'd be lost without the back brake
Spike16
Post by Spike16 »
dont agree with that tbh, any braking stands you up its just cos the rear is so fantasticly shit it dosnt make much effect and I dont do much slow town manuvering, and if im too hot into a corner I just lean over more
and rear brake wont help your turning, turning on a closed throttle will but tbh alot of corners you can take pinned on a 400 if you've got the tyre feedback and know the road well
bridgey
Bike owned: NC30,CG125 FJS600 SILVERWING
Post by bridgey »
Just get out and ride it, stop being so bloody soft. Do you always ride at exactly the speed limit.......................................
You say you're a noob???? Well if you do go out and crash at least you will have a story to tell. And chicks dig scars.
AL ;)
400GB MCN Fantasy League Champion
rich1988
Post by rich1988 »
I have scars!, infact I have a rather fetching one right next to my groin which gives me an excuse to expose myself!, indcidentally I sorted it know and fitted a new (well second hand) caliper and bled it through etc, new exhaust is llllurrvley 8-)
