NC24 (top end sluggish and drinking fuel)
- paul nc 24
- Bike owned: 2000 R1
Your expert advice is once again called upon.
just built a new 24 had some trouble getting her to fire up so systematicly changed the parts from my running bike to the new one started with my carbs as i know there set up ok and not to sure of the new ones then the electrics coils, leads,cdi ,etc all off my good bike still no joy only when i checked the plugs i found they were wet and not gapped correcty so a new set in and two turns and she fires up.
sound so i took her home last night and there is a major lack of power through topend very little throttle responce from forth gear on after 8000 rpm ?.
also it is drinking fuel like mad.
whats causing this ? can anyone tell me what ive done or what to check/sort first.
many thanks.
many thanks.
Re: NC24 (top end sluggish and drinking fuel)
Too ruch mate? All boggy and doesn't want to rev..
Hows your airfilter? whip it off and test it then - if it gets better then you know you are too rich.
Have you thought about rebuilding the forks?
- paul nc 24
The airfilter is brand spanking new. will take it off and try in a couple of hours
and the forks are new have been rebuilt, new stantions new internals and uprated springs over £300 all paid for by the previous owner
- paul nc 24
cmsmj1 sorry for not following up. just to let you this turned into another epic fault finding mission more frustrating than the manic pre cosford meet shananagans.
i wont
myself to much in the details but i have at last got it sorted after 3 nights of head scratching it was a damaged wire in the loom that fed no 3 coil.
so thanks again for the help.
i wont
