nc24, nc30 carb swap
dave_c24
Bike owned: 1991 vfr 400 nc30
Post by dave_c24 »
hi,
has anyone tried fitting nc30 carbs to an nc24, the carb necks are the same diameter,only main differnces is the slides are aout 3mm shorter on the nc30 carbs and fuel pipe diameter from tank.
My mate has a good working spare set that his bike ran very well on and we wondered if it was worth a try?
cheers dave
Re: nc24, nc30 carb swap
Are you sure the inlets are the same distances apart?
I have had a set of 24 carbs in my mitts and don't reckon they would have fit onto my NC30
Give it a blast anyways and let us know if they go on...
dave_c24
Post by dave_c24 »
CMSMJ1 wrote:Are you sure the inlets are the same distances apart?
didnt try measuring that, i will have a look tommorow ;)
cheers dave
They might do, theres not much difference between the carbs.
You could always if worst comes to worst mount them to the NC24 plate and use some linkages off the NC24 carbs etc.
dave_c24
Post by dave_c24 »
Neosophist wrote:They might do, theres not much difference between the carbs.
i think the top plates are slightly different, dont jhave them infront of me, hoping my airbox will jus bolt on though ;)
i will keep you posted
cheers dave
