r1 front end one fzr400 1wg
rockTJ
Re: r1 front end one fzr400 1wg
If the steering head bearings on the 1WG are the same as the 3TJ then you will have no probs
I also had to have an aluminium 'collar' welded in to the R1 top yoke to bring down the internal size to that of the FRZ4 stem.
I run mine with a GPS speedo at the moment, but I still got 4 stars for effort from the plod a few months back.....
I love the front end on it but I still need to get some aftermarket bars as the R1 items are in a fixed position and just a bit 'wrong'!
Good luck!
Good luck!
nestor555
- Bike owned: Honda nc29, fz400r, fzr400/600
There'd two big hoses on the rad but there's a third smaller one that's been plug up, anyone know we're it should go?
willandrip
If it is the one at the filler neck; it goes to an expansion (header) tank and should be utilised.
A pic would be handy here; there is a lot of different rads; some have a remote filler
What happened to your FZ. ?
nestor555
Cheers bud I'll try get some pics, I'm having to use my phone atm, still got her, she's in the garage hiding under a cover :-)willandrip wrote:If it is the one at the filler neck; it goes to an expansion (header) tank and should be utilised.
willandrip
If you expand the first pic of Chris' bike at the top of this page you can see the rad filler with the expansion hose.
That is a 3TJ. The Genesis has a remote filler buried under the tank cover. This is what a pic helps out with.
You might have a 600 rad !
nestor555
Hi guys this is how she stand atm.
willandrip
Appears to be an early (1989/90) engine; going by the oil cooler.
nestor555
It had a Honda varadero fairing on it when I bought it :-\
willandrip
Nestor; did you ever find any manuals or parts fiches for the FZ400 ?
nestor555
nestor555 wrote:It had a Honda varadero fairing on it when I bought it :-\
