clutch with tuned motor.
pgm
Post by pgm »
hi, could someone tell me if i need to beef my clutch up or will it work ok as it is with a tuned motor?
thanks.
abrmoto
Bike owned: RVFx5,SP1,MV F3,C90,Firestorm
Re: clutch with tuned motor.
Post by abrmoto »
No need to beef up, refresh it, but use honda plates and fit new fibre plates, dont use cheap EBC will be fecked in 4 race starts!!
pgm
Post by pgm »
thanks aly.
Cammo
Post by Cammo »
You can also add another clutch spring which helps.
lange
Post by lange »
If you add an extra clutch spring you mess up the slipperfunction. :(
Power is nothing without control!
Cammo
Post by Cammo »
lange wrote:If you add an extra clutch spring you mess up the slipperfunction. :(
Really? I've never found the slipper to be a problem with an extra spring (I use a bit of mechanical sympathy when banging down gears - but not a whole lot).
Good tip then might be to use 3 new clutch springs (they're a diaphragm spring, not coil) , I'm sure that will help clutch function.
superlite
Bike owned: TLS, LB80 x 2
Post by superlite »
I've never noticed any difference changing down with an extra spring in. Very interesting.
'Take it to the Back'
superlite wrote:I've never noticed any difference changing down with an extra spring in. Very interesting.
Me neither...
lange
Post by lange »
We tryed 4 springs on a track NC35 and the rear locked up when shifting from 6th to 2nd.
After removing the 4th spring, it all worked as it should.
I'm not shure of which type of friction plates the bike was equiped with: OEM, EBC or EBC racing.
It might work differently on a NC30 as the clutch differs and so does the number of frictionplates
Cammo
Post by Cammo »
lange wrote:We tryed 4 springs on a track NC35 and the rear locked up when shifting from 6th to 2nd.
Yeah different fibres could might alter it a bit?
Mine is an nc35 engine which it works fine on, all honda oem clutch parts and extra spring.
