Suspension question
Smitizen
Suspension question
At over 10kph my fairing hits the ground (just in front of the rear wheel) when going over largish bumps so i was wondering how to raise the rear up a cm or 2(or however high is deemed decent)? The stock suspension is height adjustable yeah?
I also hear this is good for initial turn in? Or has someone been telling me porky pies?
Cheers!
Cheers!
Re: Suspension question
I don't think it should be hitting the ground
Instead of raising the rear why not find out what is causing your bike to foul the ground and fix that ^_^
viper_biker
Buy my Hyper-Pro, that'll sort it right out.
- ibby4585
- Bike owned: SP's
ten out of ten for trying Viper!!
viper_biker
If you don't ask LOLibby4585 wrote:ten out of ten for trying Viper!!
- mo haggs
- Bike owned: bikeless
how much of the forks is sticking out of the top of the top-yoke?
try dropping the forks through the yokes a bit further.
RHG
- Bike owned: ZX636R B1H, VFR400 NC30
That will lower the whole bike, not raise the rear.mo haggs wrote:how much of the forks is sticking out of the top of the top-yoke?
- mo haggs
no it wont.
if you drop the yokes (rise the forkes) it will lower the bike
but if you do it the other way round ie drop the forks it will rise the bikes front end.
RHG
Sorry, re-read what your saying.mo haggs wrote:no it wont.
I doubt wether that would fix the problem anyway, sounds like the problem is at the rear.
Or the OP is a bat fastard.
- mo haggs
lolRHG wrote:I doubt wether that would fix the problem anyway, sounds like the problem is at the rear.
no after re-reading the post again i realise its the back and not the front thats causing the prob
