Jet kits - whats the best ?
fastdruid
Re: Jet kits - whats the best ?
The needles being worn seemed to result in a bit of hesitancy at around 5-6k, that's in a 57k bike that was[1] making a healthy 57.56bhp.
Druid
[1] It's on a different engine now for gearbox reasons.
Druid
400_Rider
Thanks for the info there Viper
I am not sure my air box has this air snorkel on ? I'll have to check and if not get one ordered.
Well the reason I am changing the needles and main jet is because there is clearly something wrong with the bike as it tops out at 109mph
also there is a huge flat spot in the mid range and the power seams hesitant.
Because I don't want to keep taking carbs off and on again etc while there in bits I might as well put new parts in there and just enjoy running the bike.
With emulsion tubes I have replaced these in the past on a Exup and man it made the world of difference, I will probably leave these if you think its not important but on the factory pro site it says even the slighest ovaling can effect running and again while the carbs are stripped I thought why not while its all in bits, but I will inspect and have a look, I just want me RVF to be the best it can be
I dont know much about the bike as its new but I am learning daily, it has a K&N style air filter, that rubber snorkel thing is missing, the bike was 5 teeth more at the rear end, it has a full tyga stainless system on it and there fueling is all messed up
I'll try and find Rick and see if he can help
Thanks again for the input
By rubber flap we dont mean the snorkle but a flat piece of rubber that attaches under the headstock.
400_Rider
Hmm not sure cant say I have seen any but I will take some pics tomorrow and fire em up so we can see
400_Rider
Could it be No 1 or 2 off this diagramme ?
fastdruid
No 2
No 1 just covers the rear cylinders
Druid
Druid
400_Rider
Lovely, thanks Druid, I'll get one ordered if I can't see it on the bike tomorrow
fastdruid
this is the view you should see when you take off the air box and look down into the headstock area
Or if you take the carbs off (ignore the washers, they're a 33BHP restriction)
Druid
Druid
hunter
running without the snorkle will effect performance.
viper_biker
Correcthunter wrote:running without the snorkle will effect performance.
