please help me
rickstar
- Bike owned: gsxr 400 gk76a
Re: please help me
does anyone no how i insert images (im useless!!!)
rickstar
Re: please help me
rickstar
Re: please help me
i think that worked u hav to copy and paste it to your address bar.
mattley87
Re: please help me
No that doesn't work, use this link, it tells you how to post images http://www.400greybike.info/newforum/vi ... f=6&t=7902" onclick="window.open(this.href);return false;
rickstar
Re: please help me
do u no how i create a photobucket. it says u have 2 do that. before u can upload photos.
rickstar
Re: please help me
think this worked.
rickstar
Re: please help me
can you please explain how this works. the DC/AC and what setting it should be on when im checking the battery/generator/regulator etc. thanks
Re: please help me
From your results - 13+V with the bike at idela and less than 12with it running - that means the generator is not charging the battery at all.
Your multimeter -
Tope left section is all VOLTS DC - turn it to the 20 option and use the two probes, one on each battery terminal.
For testing the generator - on the part of the plug that is attached to the generator wiring, rather than the other side that will lead to the Regulator.rectifier. Right hand side of the dial is VOLTS AC - two options 600 or 200. Use 200.
With the bike running you put the prongs into the connector onto wires, 1 and 2 - measure it. then 2 and 3, measure it and then 1 and 3, measure it.
There are 3 wires..so name them what you want - you should get a result form each - up to 50V AC. If not, then part of the generator is knackered.
to post images - register on photobucket> upload a photo and then when you view it on that site it will give you 4 options under it - one of them is IMG - copy that and paste it into the forum.
This is my knackered generator.... the pic is displayed - (IMG]http://i100.photobucket.com/albums/m38/ ... CF2070.jpg[/IMG)
but instead of rounded brackets ( )- you use [ ] square ones instead...
Your multimeter -
- Variablevalves suck
Re: please help me
Hi Rick.
If you download the bandit service manual it will take you through the tests. The - prob should be taken to ground and you should have more than 70V at 5000 rpm. If you set your tester to continuity and test between each yellow wire with the bike not running there should be no continuity between any of the wires.
rickstar
Re: please help me
right thanks for all the help. this is wot i got: battery-idle-14.2
battery-5k revs-13.8
stator coils-1+2-26.4
-1+3-26.7
-2+3-26.5
any ideas, thanks.
-1+3-26.7
-2+3-26.5
any ideas, thanks.
