NC30 info required
NC30 info required
Hi every one, im Calum and i am new to the forum.
Hi im looking at buying a VFR, which sounds mechanicly fine, it has race fairings with necessary holes cut out for lights it does have original fairing with it but are dropped damaged. We started the bike up jumping it from another bike battery and it started fine, then we removed the jumper leads and the bike cut out soon after. we then tryed to start it again from the spare battery but would not start, we checked the fuses and a 10A fuse had blown, the bloke who owns the bike replaced the fuse with a 15A fuse when he tried starting it up again smoke started coming out of a sealed black box at the rear of the bike.
What is this box, where can i get one from and how much will it be, how much would you pay for this bike?
Calum
Calum
Re: NC30 info required
Not sure which black box you mean. The black box set just above the number plate is the CDI and will be goosed I reckon if it's been smoking. Available fairly easily, have a look at your Regulator/Rectifier which is attached to the Seat sub frame by your left leg. Notoriously delicate and about £60 to replace. Treat yourself to a Haynes manual.
How hard can it be?
that sounds like the right box. thanks.
- Bike owned: RVF400 - ZX636
I have several CDIs at £30 each if thats what you need.I can also do you a manual at £10
that sounds great, thanks. i am still debating if i want to buy the bike so i will send you a message some time next week if i require the CDI. Thanks.
Calum
Calum
no problem.
if you decide not to buy it,let me know as I could be interested
Hey, i have decided not to buy it as he wants £500 for it and i dont want the hastle of paying that much then spending an extra £100 for CDI and Rectifier, and then finding out that it still not working.
Calum.
Calum.
pm sent
500£ is cheap, but you will most likely have some more trouble with this neglected bike. Which might put you off totally.
I think you have made the right choice.
I would guess that Geoff will buy it and it will be broken... go Geoff!
