NC23 Fluffy running
monkee
- Bike owned: 1988 CBR400RR NC23
NC23 Fluffy running
Hi,
I seem to be having a bit of fluffy running on my NC23, I have recently done the plugs and am awaiting an air filter (which are apparently quite rare!) could it just be the dirty air filter or do I need to delve deeper? How do I know if the carbs need balancing? The fluffiness is arounf the mid revs point, sort of dips then tries to pick up? Also how do I know if the bike is restricted?
Thanks for your help.
Martin
Martin
- w00dzy
Re: NC23 Fluffy running
I have two spare air filters if your interested.. one needs a clean one is new..
stimpy
rrj unrestrcted...rrk restricted
look at the colour of the label on the cdi...gold is the go...blue not so go
stimpy
stimpy
monkee
Thanks for that guys.
I'll check the CDI tomorrow.
I should find out this week if I have a new air filter incoming, if I have problems I will prob take you up on your offer woodzy.
Cheers.
Martin
Cheers.
Martin
Mikiboy
- Bike owned: RVF400 NC23 x 2 NC29 CBR4/600
If its 88, its the rrj unrestricted.
Likely to need dyno set up if you have aftermarket downpipes, can or exhaust
Roger at Corby Kawaski is good with CBR's on the dyno.
monkee
Thanks, it isn't restricted and I've had it out for a run today, it has a cut down blue flame exhaust on that I don't think the previous owner has sorted out. Once I have my air filter I'll invest in a bit of dyno time.
Cheers all.
Martin
Cheers all.
Martin
