Growler, you just need to weld up the old hole and drill a new one 8mm (centre-centre measurement) further down. Measure where it needs to be first as you won't be able to find the centre of the old hole when it's welded and filed smooth!Growler wrote:Is this something you can do yourself? and if so any instructions would be gratefully received... Have the welder poised and ready to go as I type!!!
You only need to weld the standard hole up as the new one will slightly run into it if it was left there.
