NC35 Spark plugs
badbannedbiker
- Bike owned: nc29 nc30 gsxr750 T675 CRF450
NC35 Spark plugs
do rvf's tend to eat spark plugs? Left mine sitting for a fortnight, possibly with the throttle stuck open and tap on. Tried fresh fuel and it won't bump. Tested the coils with a spare plug and got sparks. Then took out and checked the fitted plugs and found no or v v weak spark on all plugs. Is it usual for them just to go for reasons of flooding or similar? New plugs are expensive so I'd like to avoid it in the future
Re: NC35 Spark plugs
In a word...yes
badbannedbiker
Well thats a bit shit then...£30 for a set of 4!!!
Yep, I killed my first set years ago just by playing with the throttle too much when it wasn't running....a lesson you only need to learn once!
badbannedbiker
new plugs solved it...thank god
vfrgav
- Bike owned: 1990 NC30 2009 CRF450
ive found out quickly in my short vfr life not to turn the throttle with the engine off. But both times i just took the plugs out and let the combustion chambers dry out over night. same plugs back in after a clean up and dry off and away she goes
badbannedbiker
I'll try that next time. I ran the bike with the fuel off till all the petrol in the carbs was gone to try prevent it happening again
