cdi for nc23 vs vfr
leithncbr400
Bike owned: gsxr1000 k8,cbr400 nc23&29
cdi for nc23 vs vfr
Post by leithncbr400 »
can any one tell me if a cdi unit from a vfr 400 will fit a nc23 cbr 400 the plug configuration looks identical and the numbering is the ky2 oki electrics? thanks Nick :whistle:
Re: cdi for nc23 vs vfr
doubt it very much as the VFR is a 360 degree crank V 4 and does not fire like an IL4 bike does..
Try it...let us know!
leithncbr400
but doesnt the pulse generator control the firing timing and the cdi Capacitor Discharge Ihgnition only delivers the spark as requested by the pulse genrator!!!???
leopard_pagan
Post by leopard_pagan »
*sits back and flicks popcorn at the entertainment*
leopard_pagan wrote:*sits back and flicks popcorn at the entertainment*
:popcorn:
Yes...but it is not that simple is it?
The RVF and VFR have different pickups for startes and they are the same engine. I don't see that the CBR is going to work..but I am happy to learn otherwise if oyu reckon it can be done.
I reckon there is more than the prompt to fire the plugs that somes from the CDI...
Cammo
Post by Cammo »
:popcorn:
It also controls the timing.
So, assuming the vfr cdi works on an nc23, you'll be stuck with the vfr timing which will be different to the nc23's.
This could be better or worse...
greggo
Post by greggo »
It would not surprise me if they were interchangeable, but the advance/retard curves are probably quite different to suit the two different engines. 10 minutes with a couple of wiring diagrams would help.
I would say this:
1. Plug it in and if you can get it to start, then they are interchangeable.
2. If you get it running stick it on a dyno and find out if the advance/retard curve is better/worse/the same.
3. If you blow up the engine it ain't my fault nancy. :Bmods:
Right. You have your homework, now hop to it and report back here by Wednesday. :scare:
zul_cbr
Bike owned: 1990 CBR400RR-L NC29
Post by zul_cbr »
i dun know if nc30 cdi will fit nc23.
but, from my experience on the other bikes,
ZZR250 cdi fit ZXR250 although it has different part code. tested and working.
noted that ZZR250 is 2-cylinder inline while ZXR250 is 4-cylinder inline.
stimpy
Post by stimpy »
but...but why?
is all i want to know
stimpy
leopard_pagan
VFR/RVF any V4 = Image
CBR/ZXR any IL4 = Image
