nc23 engine - shiny rh casing?
wig
Post by wig »
I have just fitted a replacement engine into my nc23
it is ace but has a shiny right hand engine casing? I cant find a picture of an engine with one and was wandering if anyone know where this was from? was it with a certain year or an upgrade/downgrade by the previous engine owner?
cheers
garyboy_palaboy
Re: nc23 engine - shiny rh casing?
Post by garyboy_palaboy »
maybe it was buffed.....just like mine....
wig
Post by wig »
oh right didnt think of that. the grooves where honda is written also look less pronounced etc which is what made me think it may be from a different year/model etc
drifterwannab
Post by drifterwannab »
yeah probably just had the paint stripped and buffed up.
if the ridges on the casing are lower it might have had a bit of a grind back, due to damage from a low speed slide or just to make it look better
wig
Post by wig »
The pickup/pulse generator was ago grey and a different style - but looking at it tonight - i think your right about it beign buffed shiny.
how crap is that.
I think i will remove the rh casing of spare engine as it is the original nice gold colour
cheers for the input u lot
stimpy
Post by stimpy »
the cbr400r aero had silver/ engine cases
stimpy
wig
Post by wig »
grim, i may have an engine from an aero. thats quite depressing as they are so ugly, but it works which is more important.
cheers for the info
stimpy
Post by stimpy »
you will know if you have an aero motor in a tri arm...modified airbox to fit a tri-arm frame and an external oil cooler just for starters
the covers are interchangable
raced with an aero motor in my first triarm...went hard...that is after ALOT of mucking about just to get it to go
stimpy
wig
Post by wig »
cool cheers stimpy definatley not an aero then.
cheers
stimpy
Post by stimpy »
stimpy
