How hot does your reg/rec get?
Greetings people, I have been resealing my genny cover and sorting the gsxr rotor stuff. Got it sorted, seems oil tight now
Anyways, I was warming the bike up and was felt the heat from the reg/rec as I was leaning over the bike. It was bloody hot to touch. Wet finger would just about sizzle on the cooling fins. The wire feeding it was very warm too. This is a replacement finned electrex one from 2 years ago - my original went pop due to knackered windings.
So....I have never felt how hot my reg rec goes before...are they always as hot as this and we don't notice?
Who knows how hot it is supposed to be? Go and start your bike after a couple of minutes - how hot is your reg rec?
Spike16
Re: How hot does your reg/rec get?
mine dosnt have fins and it dosnt really get hot, i have replaced the block connector recently but thats it
rswspeed1
when i was testing mine last month i could of fried an egg on it (if i would of put the bike on its side, which i didnt realy fancy)
again dont know if its normal but my arm touched it and a little squeek came out of my mouth
it was that hot
My R6 regs get toasty but not hot.
These things are BIG, probably twice the surface area of a finned honda unit.
@ Spike: I'd be changing that thing or carrying a spare mate! Those things go pop at the most odd times.
Cheers guys, sounds like hot is normal.
I'll sticka pic up of it - it is not small by any stretch...but it could griddle some cow quite nicely..
wullvfr
- Bike owned: zx9r c1
i wouldn't worry about it,so long as the charge rates are all hunky dory then it's doing it's job well enough.
wull
wull
Spike16
yeh il be getting a spare soon but its seems to work 100% touch wood
RonniB
I run a special rec/reg that is handmade by a guy here in Denmark, we did a bench test on it which showed it would go up to 79 degrees celcius and there was a voltage drop of 0.05v compared to cold. So a oem (that work after another principle) will get very hot is no shock.
Ronni
Ronni
That is bloody hot...
This is the offending article...
Smoky
been burnt by my one too... although ive seen somewhere that you can attach a CPU cooler to it, the fan is just the right size- doesnt do an amazing job of keeping it cool, but if i remember right i think it was about a 12 to 15 degree decrease...
