newbie with nc30 issues
Re: newbie with nc30 issues
mikevo wrote:
1 question if you rev on spot should it rev out cleanly ??
Mine don't when they're cold.
mikevo
right bike is now reving from idle but on riding it only revs to 5.5k so i assume its in limp mode
right what i need to know is what can cause it to go into limp made ?
i know the speedo does but the speedo is working fine
what else make it go limp mode
help needed
help needed
Woohoo - bonus - we are nearly there!
The limp mode is because the CDI cannot see the speedo - behind the clocks the speedo plugs into a small 3 pin socket - if you had an M Max or other dersitrcotr - it would plug in here. If this is unplugged..plug it in. This 3 pin goes to a larger 6? pin block where the idiot lights also join the lager block. make sure this is all peachy and you have good connections.
The loom mighthave been modded and someone put a resistor in the loop - find that and check it is solder, crimped r whatevr - just find it.lol and make sure it is solid.
You are nearly done man..well done for the patience you have shown - I'll bet the moto rewards you with some good fun now (oo err missus)
But yeah, the CDI and the Speedo are not in touch...make them talk and you are rocking!
mikevo
i have a m max derestictor but it plugs in between loom and cdi
speedo does read mph as rode it yesterday
is it worth me changing the speedo
is this the only thing that makes it go into limp mode ?
mikevo
right i have totally had it with this bike now
changed the speedo and the ignition pick ups and has not made a blind bit of difference
the bike revs to 5.5k but no more
the you first try to rev from idle front right cylinder appears to be popping (back firing through carb)
took off the timing cover and tried to strobe it up but couldnt get my car strobe to work on it
found i appear to have quite a lot of crank case compression ,is this normal ? engine doesnt smoke !!
please please help i have now run out of idea and got to the end of my tether with it
mikevo
ANYONE please help
if not fixed in week will sell both so offers by pm
mikevo
as no one can help me sort it and even bike mechanic stumped the bike is going back and i will have to take the lose of roughly 500 gbp which isnt the best of times as being made redundent at end of june
thanks for the help just wish i could have sorted it
- Matchlessman
Mike,
It sounds like you may have been a bit ripped off by whoever sold you the bike. You say that you bought it as a non-runner and it just needed the exhaust putting on, its obviously not been that simple.
If the bike is going back to where you got it from, how come you are going to take a £500 loss?
Too many bikes, so little time!
mikevo
because i stupidly bought bits and pieces to try and fix it like cdi plugs etc
and paid the useless mechanic 160 to do f..... all
just want a bike to get on and ride
anyone know of good bike going for resonable money with 50 ish mile of kent please let me know
hunter
Did you change the carbs for the other set that you have,if not then do so.
