dyno results inc graphs....
- vfrman
- Bike owned: NC30, 1098s
Re: dyno results inc graphs....
It looks pretty good, but if you MUST mess with it, try a 1/4 turn out on the idle screws and maybe take out .5mm of shim on the needles. TBH I would just fix the lean condition at idle. A tad rich is always better on a motor than a tad lean.
g-force performance
- Bike owned: VTR-250, VFR400RR,
See how the power has little drops/dips everywhere coming up the power curve? Also, see how, when you shift during the All Gear the power drops away from a flat? You're too lean by at least a few jet sizes on the main. Can't tell what the midramge is doing, need to see a Fast Acceleration (FA) type run for that. That would help with the needle tuning. Overall power looks good for stock. Making it richer will make it smoother and cooler. But, your fuel economy will be a tad lower.
Mike Norman
G-Force Engine Development
Mike Norman
- vfrman
g-force performance wrote:See how the power has little drops/dips everywhere coming up the power curve? Also, see how, when you shift during the All Gear the power drops away from a flat? You're too lean by at least a few jet sizes on the main. Can't tell what the midramge is doing, need to see a Fast Acceleration (FA) type run for that. That would help with the needle tuning. Overall power looks good for stock. Making it richer will make it smoother and cooler. But, your fuel economy will be a tad lower.
Mike Norman
And I stand corrected. I was just looking at the a/f graph.
powerbio
cheers guys....as ive said im currently running 118f 120r main jets....so what would be a good size to go upto?...124f 126r??
thanks
duncan
thanks
duncan
g-force performance
Yeah that's a good start. Is ther ea jet kit in the bike now? If so, who makes it? I have seen this very tuning issue before.powerbio wrote:cheers guys....as ive said im currently running 118f 120r main jets....so what would be a good size to go upto?...124f 126r??
thanks
duncan
Mike Norman
powerbio
hi
no jet kit just doing mods thats been suggested on here.
slides drilled from 2mm to 2.5mm
main-jets 118f 120r
pilot screw 2.25 turns out
needles shimmed from 0.5mm to 1mm
ill try the bigger jets and go from there
thanks
duncan
main-jets 118f 120r
thanks
duncan
