VFR and RVF fork pinch bolts
Are they the same? The little bolt at the bottom of the fork legs is the one I'm talking off.
- abrmoto
Re: VFR and RVF fork pinch bolts
think rvf are slighty longer from memory but not 100%
You couldn't do me a favour and offer up a measuring tape to a spare you you might have lying about and I'll do the same. Actually, another one I'm curious on is the axle pinch bolt too, are they the same?
- abrmoto
Pinch bolts are interchangeable but think NC30 is 22m and rvf is 24mm, or that might be the Ti ones I run on RVF's but are defo interchangeable, spindle different, cant measure one as at work now, can tonight if you still need info.
Aly
Aly
Cheers Aly, I have a Ti axle bolt on the RWU forks and wondered if it would fit the USD ones too, so that's a yes then. That's one thing I can keep then :D
- Martin
That's a no then isn't it?abrmoto wrote:Pinch bolts are interchangeable, spindle different
Aly
Too spensiff!!!
Erm, I dunno, I'm lost
These bolts from a VFR, will they fit an RVF?
- abrmoto
Viper, I know what you are on about, pinch bolts not 100%, axle bolt will fit.
I have some nice allen stainless ones if your nc30 ones dont fit.
- Martin
