dyno results inc graphs....
hi all
i had my nc30 on the dyno today.
the guy said that it is running a bit lean on idle...so looks like ill need to screw the pilot screws out maybe half a turn and he also said that in the midrange it seemed to be a bit lean but doesnt think that it is the needles and has suggetsed that i go from 118f 120r to 120f 122r on the main jets.
it made 61.23bhp. mods are scorpion race can cut down.....needles shimmed to 1mm and as stated main jets at 118f 120r. pilot screws set at 2.25 turns out. slides drilled to 2.5mm.
what do you people think?
many thanks
many thanks
Re: dyno results inc graphs....
thats very good power for a virtually standard bike, iv got the exct same setup si iil have a go with your setting and see how it goes
I hadmy bike dyno'd today too, I think that's a 'perfect' graph,
- Bike owned: All sorts
Very Good power output there :) Nice one...
Skint Novice F400
- vfrman
- Bike owned: NC30, 1098s
viper_biker wrote:I hadmy bike dyno'd today too, I think that's a 'perfect' graph,
Looks a tad lean at idle, and a little rich in the low-midrange....
LOLvfrman wrote:Looks a tad rich at idle, and a little lean in the low-midrange....
- vfrman
Yeah, I got those mixed up. I fixed it.
I would not worry about what the dyno man says, but more of how it rides on the road.powerbio wrote:hi all
many thanks
If you can come out of a tight 20mph corner in 3rd, wind the throttle wide open, and it revs to the redline then id be happy with that.
Running lean on idle etc, you never tend to use it at idle..
Regards,
Alias
so any comments on what my graphs show?
