nc23 tri arm light head bulbs
- lloydiecbr
- Bike owned: VTR1000
as above . what tipe are they and where to get them from . any help will be very great thank you
Re: nc23 tri arm light head bulbs
David Silver or ask LP to send you a copy of the H4 conversion.
H4 conversion headlight unit (NOT bulb) also requires the relay mod which i dont have... yet
you can fit normal H4 bulbs in by bodging the lower 2 location tabs. BUT as mentioned they can burn out the dip switch = replacing switch gear. so the Relay mod is a must for peace of mind.
the mod linked is for a NC29s headlights... as that is what i own.. i dont know if the NC23 has the same set up.
http://i18.photobucket.com/albums/b145/ ... ghtMod.jpg" onclick="window.open(this.href);return false;
- lloydiecbr
thank you 2 . as im using my 600 loom witch is for uk bulbs i will get the dremal .
PLEASE check that NC23 headlight units are similar or same as NC29 ones (in the pics) before you start cutting. if they arent the same.. at least the mod an be used as a guide..
- lloydiecbr
they look the same ish . im getting used to chopping jap things up !
Don't go too deep or you'll screw up the beam angels.
Hows the rest of the bike looking.
- lloydiecbr
its been up dated . more pick on tuesday .
ya i think i will have to take my time when doing it
