Nc30 Poor running in wet condition
Can anyone help me please. I have noticed in heavy rain, That my bike feels as if it running on 3 cyclinders, at times the only way to clear this is to open the throttle and let the engine revs build up and then it seems to kick back in onto all cylinders. its as if the H.T. leads or coils are shorting out. this problem only happens in heavy rain conditions. runs fine in the dry. Thanks.
- Bike owned: zx9r c1
Re: Nc30 Poor running in wet condition
you have kind of answered your own question bud,have a good look at the igntion system,check ht leads coils and the cdi.make sure there is no build up of water in and around the cdi and make sure all connections are hunky dory.
william
william
As above i always had the same problems as this when i had my old mini. It just hated rain.
I think there are drain holes for when the spark plug recesses fill with water, check to see if they're blocked.
NC30 cdi's are far from waterproof also, check to see whether rain from the rear tyre is getting under the pillion seat.
Thanks again for the info, i will give things a good check over at the weekend
This always happens to me, if the bike has sat in heavy rain for a while. After about 10 mins of riding it, it sorts itself out, obviously whatever was wet has dried again. I wouldn't worry about it.
- Matchlessman
I also had a mini and that used to suffer in the wet.
WD40 was the way to go, sprayed liberally over the ht leads, plug caps and distributor and everything worked fine.
Too many bikes, so little time!
Thanks for the help. does anyone know where to get good new H.T. Leads from, i contacted my local Honda dealer and they where priced at 130 pound inc VAT. pretty steep i thought !
Have a ring around some bike shops and motorfactors and see if they sell it off the roll i bought six foot for £10.
