how do i find out what year my bike is?
Smoky
sorry for the noob question, but am after some new fork springs and need to know the exact year- not sure if its a 90 or 91...
thanks guys...
thanks guys...
Re: how do i find out what year my bike is?
All you need to know is whether you have the early model forks or the late model forks.
Early forks haev a preload only adjuster on top, the later ones have a brass screw inset into the preload adjuster as well.
early preload only forks on 89 bikes, the rest have adjusters for rebound too.
Smoky
well there is a screw set into the nut on top of the forks, but its not brass- its silver...
they do look adjustable come to think of it...
OK - you have old forks then.
Yours should be a 22mm bolt in the fork top and a large, flat head screw thread sticking out of it?
The later forks have the same large bolts, a different preload bit and in the middle a small brass screw.
No brass = old forks.
Hope this helps.
What springs you after anyways? If you wanted to upgrade you want to be looking at Hagon progressive springs or a Rick Oliver kit which uncludes spings, spacers and oil level tools etc - bargain.
The older forks are a damping rod fork - they are not externally adjustable whereas the newer forksmare a cartridge fork which has the screw adjustability for rebound. You can intermally change compression damping too if you felt the need.
I use the old forks BTW - love them. Rebuilt with Hagon springs, 10w oil and a smaller air gap than std - cannot recall off the top of my head but think I used 500ml of oil rather than 490 - If I recall this correctly! LOL - am redoing them in the next few months so will have to measure it then!
Hope this helps.
Smoky
thought they might be...
am after the hagon progressive ones, dont think mine have ever been changed, so i reckon its about time lol.
thanks for all the help dude, much appriciated...
- Sligeach
these are old ones
Smoky
yup- those be my forks....
cheers dude
cheers dude
Is that a case of the picture telling a thousand words...lol
rock on!
rock on!
Smoky
ok, so sorry to raise a topic from the dead here.. but can you guys settle an argument for me?
are these the old or new type forks?
- Smev
- Bike owned: NC30 of course
