handlebar conversion
RICKNC31
Hi i have just put a handlebar conversion on my HONDA CB1 as i do not like the clipons much so i will try and post a picture[img][IMG]http://i1123.photobucket.com/albums/l54 ... CF0465.jpg[/img][/img]
RICKNC31
Re: handlebar conversion
Hi i followed the instructions on how to post pictures copy and paste between the image box but all i post is the photobucket code no picture so could you pc experts post my pictures for me please many thanks rick
tomigun
- Bike owned: HondaCB400sf version R
Hi Ricknc,just copy and paste the (image code box).
Nice conversion!!
Nice conversion!!
RICKNC31
thanks for that i will try again [img][IMG]http://i1123.photobucket.com/albums/l54 ... CF0459.jpg[/img][/img] no did that still only get the photobucket code no pictures perhaps i will stop trying
amorti
- Bike owned: CB-1, MSX125
The other way is use a Revere front yoke. You do have to stand the forks a bit taller though.
I didn't like straight bars on my -1, but it's all personal taste when it comes to ergos.
Good job :)
Good job :)
RICKNC31
Hi i saw at a bike show today a HONDA VT 400 bros that had standard 41mm alloy clamp to the top of the forks bars on these had a rise of about 3" and would fit strait on my cb1 without moving the forks or changing the top yoke at all and would be a good way to get a better riding position which is what i wanted still my conversion is done now
amorti
Not sure the originals ona bros are any higher he may have had VFR bars fitted?
RICKNC31
ok but it gave nearly as much rise as my conversion with a much neater look still i already had the bar risers and handlebars that i used and i only had to bore out the risers to 41mm from 38mm to fit them with a longer clutch choke and throttle cables which i also had so mine was a very cheap to do conversion which is good for my wallet all the best rick
Markherbert
If you want flatbars on the bike a cb400sf yoke will give this.
Bros’s have a few different height bars from what I’ve seen I expect depends on year
