handlebar conversion
RICKNC31
Post by RICKNC31 »
Hi i have just put a handlebar conversion on my HONDA CB1 as i do not like the clipons much so i will try and post a picture[img][IMG]http://i1123.photobucket.com/albums/l54 ... CF0465.jpg[/img][/img]
RICKNC31
Re: handlebar conversion
Post by RICKNC31 »
Hi i followed the instructions on how to post pictures copy and paste between the image box but all i post is the photobucket code no picture so could you pc experts post my pictures for me please many thanks rick
tomigun
Bike owned: HondaCB400sf version R
Post by tomigun »
Hi Ricknc,just copy and paste the (image code box).
Nice conversion!! :geek:
RICKNC31
Post by RICKNC31 »
thanks for that i will try again [img][IMG]http://i1123.photobucket.com/albums/l54 ... CF0459.jpg[/img][/img] no did that still only get the photobucket code no pictures perhaps i will stop trying
amorti
Regular Member
Bike owned: CB-1, MSX125
Post by amorti »
The other way is use a Revere front yoke. You do have to stand the forks a bit taller though.
I didn't like straight bars on my -1, but it's all personal taste when it comes to ergos.
Good job :)
RICKNC31
Post by RICKNC31 »
Hi i saw at a bike show today a HONDA VT 400 bros that had standard 41mm alloy clamp to the top of the forks bars on these had a rise of about 3" and would fit strait on my cb1 without moving the forks or changing the top yoke at all and would be a good way to get a better riding position which is what i wanted still my conversion is done now
amorti
Regular Member
Post by amorti »
Not sure the originals ona bros are any higher he may have had VFR bars fitted?
RICKNC31
Post by RICKNC31 »
ok but it gave nearly as much rise as my conversion with a much neater look still i already had the bar risers and handlebars that i used and i only had to bore out the risers to 41mm from 38mm to fit them with a longer clutch choke and throttle cables which i also had so mine was a very cheap to do conversion which is good for my wallet all the best rick
Markherbert
Post by Markherbert »
If you want flatbars on the bike a cb400sf yoke will give this.
Bros’s have a few different height bars from what I’ve seen I expect depends on year
