Clutch Problem - Please Help!
maciekmaciek19
Re: Clutch Problem - Please Help!
Thanks mate, very useful.
Just emailed that to the supplier. He seems quite cooperative so there is a chance to get the plates replaced.
The pain is I will need to do the work again, get another gasket and centre nut...
maciekmaciek19
Hi there,
Just to let you know I have finally received the right plates. Installed last night and tested this morning.
The clutch feels so much better. ALMOST no drag... Almost because I've noticed that there is a little drag when engine is warmed up. I think it might be the oil... Some brands cause clutch drag right? I'm running on some crap oil (new but not a good brand)
Can you guys confirm what is the best oil I could use on this bike (NC35) I guess it's probably too old to run on full synthetic? Let me know if you can so I could sort this bike out.
Cheers!
Cheers!
Yeah stay away from full synthetic, it can make your clutch slip.
Plenty of good oils to choose from.
- Psychosomatic88
Full synthetic oil will only make your clutch slip if it contains a viscosity stabiliser and other such additives. These oil are designed generally for car engines or where a wet clutch is not used.
Bike specific FS oil should not contain these additives. I always buy FS Castrol R4 superbike oil for anything I care about and have used it in a few bikes with no ill effects. It does however cost a lot of bread. Castrol's semi synthetic 10W40 should be fine for normal use.
Going on the internet is like owning a gun... Just point, click, then shit your pants waiting for the Police to turn up.
